Wi-Fi
Yarakalidayi
Message 2 of 2
recently I have got a new contract with talk talk at a much cheaper price. I have Ethernet cable plugged in and ever since this new contract the wifi has been unbelievably slower nothing works definitely wouldn’t recommend TalkTalk to anybody been with them for many years and definitely not be renewing again
1 REPLY 1
Message 1 of 2
Hi @Yarakalidayi
I can help with all Wi-Fi issues, if you want. Which make/model of router are you using?
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
The information below is provided by TalkTalk. For confirmation, please contact @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
