on 03-06-2024 03:01 PM
The WiFi connection to my smart TV keeps dropping off. I do not know why as this kind thing did not happen when I was using Virgin Media
on 04-06-2024 07:32 AM
Hi Steve9898
Please can you add your name and TalkTalk landline number to your Community Profile, I can then check which router you have.
Thanks for your help @KeithFrench
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue. Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others. If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc. one of the TalkTalk team will jump in and help out.
on 03-06-2024 03:56 PM
It will either be an Amazon Eero or it will be a Sagemcom FAST 5364 or 5464. If you look on the back of the router & it is a Sagemcom, there will be a pull up panel at the top. Behind that is a label which will tell you the model number.
I will PM you a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it. Collect the screenshots that I require and include them in your reply. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
on 03-06-2024 03:49 PM
Thanks Keith
Please help. My WiFi route was just installed in April and I do not know the make/model.
on 03-06-2024 03:02 PM
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
