on 18-01-2025 03:29 PM
My (not fibre) broadband is giving an unreliable and variable speeds. This is for my laptop as well as iphone 13. The download speed can change from 19mbps to ZERO mbps within minutes. Even when there is a claimed speed of 19 the refresh rate on Chrome is very slow. Attached are speedsd for the last 2 days.
Can anyone in Talktalk help?
on 03-05-2025 09:54 AM
Thanks for letting us know, @mackerel. Good luck with your new service.
on 03-05-2025 09:29 AM
Too late!! I became so fed up with the pathetic broadband service that I've cancelled my contract
on 02-05-2025 10:35 PM
If you still need help with this, @mackerel, I can re-escalate the thread for staff attention.
Better to post back on here, rather than last year's one, which another customer used earlier today, causing some confusion.
There's not likely to be much staff support before Tuesday, with the Bank Holiday.
Let me know if you would rather this thread were closed to new posts.
on 31-03-2025 07:39 AM
Hi @mackerel
I'm really sorry to hear this. Did James know that the fault was still present when you spoke to him?
on 28-03-2025 02:58 PM
James rang on Monday to monitor the changes he had made, but there was little difference. In other words, I'm still getting random outages and variations in speed. I will be leaving Talktalk as soon as I can.
on 25-03-2025 10:52 AM
Hi mackerel
Is my colleague from our faults escalation team still in contact with you?
on 21-03-2025 11:56 AM
Things not noticeably improved yet, but I have noticed that if there does appear to be a workable service and I do a speed check which yields a good result, the system immediately reverts to being unuseable. Perhaps speed testing over-stresses the system. I have to restart the router after that. Don't know if I'm right or whether this is useful
on 19-03-2025 10:15 AM
Hi @mackerel
I'm so sorry again for all the delays.
Our Faults escalation team have confirmed that they have now made contact with you.
on 18-03-2025 09:54 AM
Debbie - another day and no response from your network team.
on 17-03-2025 11:35 AM
Hi @mackerel
I'm really sorry for the delay. I've chased the team for updates and I will post back here as soon as they come back to me.
on 17-03-2025 10:45 AM
Chris - still exactly the same wild fluctuations. Problem is with laptop, PC, iphone, ipad and TV. All with no service. I noticed one of my extender's lights fluctuating from none to three all the time. No response at all from network team. Current speeds below.
I'm sending this now as it seems there is a slight break in my internet blackout for a moment. Note that within a minute the download goes from hero to zero.
Please can you get something done?
on 14-03-2025 10:53 AM
OK thanks. I'll pass it over to our network team and ask them to take a look
on 14-03-2025 10:51 AM
Chris - this morning download is 19.5 which is about as good as I ever get. The fluctuation is from this figure to undetectable speeds of download, although my internet icon shows that I am connected. So I think it is fluctuations mainly, although most mornings I do get messages on some apps that my internet has been restored. Both are unacceptable and I seem to suffer them both.
on 14-03-2025 10:35 AM
Sorry, just to confirm, you have currently got a broadband connection haven't you, it's just that the speed is fluctuating?
on 14-03-2025 10:29 AM
Chris - I have no problem with you running diagnostics, but your toaster analogy falls short. If I had no electricity (like no broadband) they wouldn't ask me to tinker. Anyway this doesn't get us further forward. Last time I was contacted by your network team, I regret to say they seemed to know nothing, so I hope this is better. Incidentally, I connected an ethernet cable with same results - or lack of them.
on 14-03-2025 09:53 AM
I'm sorry but we do need to run through diagnostics. I disagree that you wouldn't have to do this with water or electricity. If you contacted your utilities company and told them that your toaster isn't working I'm sure they would ask you to run through some diagnostics rather than just assume that there is a fault with the electricity supply (especially if they run tests that show no fault)
As this keeps on happening, I'll pass it over to our network team and ask them to take a look. I'll let you know when I receive an update or they may contact you directly
on 13-03-2025 04:27 PM
Oops - I spoke too soon. Laptop has download of 0.2 so that although I technically have internet service it is too slow to make anything work. iPhone is now a blistering 4.2 mbps download
on 13-03-2025 04:20 PM
Well - what do you know. As a gift from the gods, the laptop is now working - but i had to reset the router. If my water supply isn't working properly, I never get asked to check all the pipes, and the same for electricity. You have contracted to supply a service and I expect it to not require my intervention at random times to make it work.
on 13-03-2025 04:10 PM
Chris - it’s Broadbandspeedchecker. You always make the comment that the speed seems ok but the service is erratic at best. At present (and this will probably change in a minute) I have no service to laptop and tv but iPhone is working. Look though all the correspondence a month ago. I am not your engineer so I can’t answer all your questions. I just think that this should not happen nor should it keep happening. Any response will be patchy as I keep having no internet.
on 13-03-2025 02:48 PM
Hi mackerel,
Could I just ask which speed tester you used, the upstream results don't make any sense, they are much higher than they can possibly be
