on 18-01-2025 03:29 PM
My (not fibre) broadband is giving an unreliable and variable speeds. This is for my laptop as well as iphone 13. The download speed can change from 19mbps to ZERO mbps within minutes. Even when there is a claimed speed of 19 the refresh rate on Chrome is very slow. Attached are speedsd for the last 2 days.
Can anyone in Talktalk help?
on 20-01-2025 01:34 PM
Sorry for delay in replying - no internet. I'm taking this brief opportunity to reply. Thanks, Gliwmaeden2, for answer (which is what I guessed it might be, but it hasn't solved the problem.
Chris - no, it's still a problem (the same). I thought a windows update may have caused problems so I did a hard reboot of laptop and it connected briefly (ie, now). However, although it shows I'm connected, this is only theoretical as the speed figures show.
The same pattern applies on my iphone 13. So, the issue seems to be unreliable, disappearing, and fluctuating supply of the broadband connection. I dion't know if this connection will last and whether I will be able to see any responses.
on 20-01-2025 09:10 AM
Hi Mackerel
How are you getting on, how has it been since your last post?
on 19-01-2025 10:54 AM
It's not so much that nobody has any problems at the weekend @mackerel , just that this forum is not considered to be immediate, real-time support. Even during the week it may take staff a day or two to get to you depending on how busy they are.
If you need urgent support at the weekend phone support is available on Saturdays and live chat is available both Saturday and Sunday. All information including opening hours here: How to contact TalkTalk Broadband - TalkTalk Help & Support
on 19-01-2025 10:22 AM
@mackerel, it just means simply switch off the router at the power button for 30 minutes and then press that same button again to get going afterwards.
It's not a factory reset.
But does need to be 30 minutes minimum.
on 19-01-2025 10:20 AM
Divsec - thanks for the response. It's wifi. I'm afraid I don't know what a 30 minute reboot is. Shame no TT team is in. Is it because no-one has any problems at the weekend? Mackerel
on 18-01-2025 03:54 PM
Hi @mackerel are we talking WiFi or ethernet, or both?
Have you tried a 30 minute reboot for your router?
Your post has been escalated but the TT team will not be in till Monday.
