Wired connection will not work
S7777
Message 12 of 12
My pc will not work on the internet via a wired connection.
No idea why, was fine yesterday her all wired connections are now not working! I use and need this for when I work from home as well as for use with several hobbies and am now stuck.
11 REPLIES 11
Message 1 of 12
Hi S7777
Are wired connections still not working?
S7777
Message 2 of 12
@Debbie-TalkTalk  yes I have and I have returned the old one.
Not much difference. For the price I pay per month the service isn't good enough. Will be leaving in the next week or so
Message 3 of 12
Message 4 of 12
Hi @S7777
Thank you 🙂
Let us know how the connection compares with the replacement router.
Thanks again.
Message 5 of 12
Added details to profile
Message 6 of 12
HI @S7777
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
S7777
Message 7 of 12
I will try a new router if you send one
Message 8 of 12
Hi S7777
Would you like me to send a new router for testing?
S7777
Message 9 of 12
I have to reset the router almost every day for the wired connection to work. Fed up with problems and will be leaving talk talk very soon to be honest
Message 10 of 12
Hi S7777
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Message 11 of 12
What make/model of router do you have?
Please can you go to the command prompt if it is a Windows PC and issue this command followed by the Enter key:-
ipconfig /all
Then copy the output & paste it into a PM to me(to preserve your privacy).
