Wireless Speed decreases during the day
Richardtalk
Message 6 of 6
The signal to my house is always good, at around 67mbps but the speed from my router via wifi decreases with time. If I reset the router it si around 65mbps but as time passes it gets slower and slower. This morning it was around 5mbps. I reset the router and bingo, straight back up to 65mbps.
Is this a router issue as it happens every day and is not connected to devices connected or anything else I can think of. It just seems to decay over a 24h period?
5 REPLIES 5
Message 1 of 6
Thanks. I think the problem you are experiencing is probably due to wifi congestion as all local wifi channels are showing as congested. Are you able to test with a device connected to your router by Ethernet cable?
Richardtalk
Message 2 of 6
Talktalk phone number added!
Message 3 of 6
Hi Richard,
Thanks but could you also please add your TalkTalk landline telephone number
Richardtalk
Message 4 of 6
Done I think!
Message 5 of 6
  • Name
  • Telephone number
  • Alternative contact number
