on 26-11-2021 11:38 PM
my internet has been disconnecting every few minutes since about 5pm yesterday, i have truned off router for 30 minutes then turned back on, connected then started to disconnect again, just managed to get this message up, im wondering if its something to do with the weather ?
the router has not been changed or moved, this is something outside of the house.
on 02-12-2021 02:43 PM
OK, thanks for letting us know
on 02-12-2021 02:40 PM
tirned off reouter for 30 min, thne back on its returned to 38mb thank you
on 02-12-2021 06:33 AM
I've re-checked the connection stats now and the sync speed has increased. If there is still no improvement in throughput speeds then please can you try powering down the router for a full 30 minutes and then retest the speeds again as this will reset the current session and can often increase the throughput speeds.
on 01-12-2021 04:45 PM
no improvement in download speed 25mb
on 29-11-2021 03:21 PM
OK thanks 🙂
on 29-11-2021 03:16 PM
ok thanks, i will keep checking speeds etc
on 29-11-2021 03:01 PM
Hi spirit1,
As ferguson has said, DLM will at least 48 hours to respond to any improvement by moving you to a faster profile
on 29-11-2021 02:58 PM
It won't change immediately. DLM will monitor your line and if it is seen to be stable any adjustments will happen in the small hours. Give it a couple of days as the support team have advised.
on 29-11-2021 02:55 PM
still getting 24.7 mb even in test socket
on 29-11-2021 02:51 PM
OK thanks, could you leave it there for 48 hours and we'll see if DLM moves you to a faster profile
on 29-11-2021 02:47 PM
iv just done that after finding microfilter, all plugged into test socket.
on 29-11-2021 12:42 PM
Hi spirit1,
Have you tried posting the photo using the camera (insert photo) icon?
on 29-11-2021 12:20 PM
After you have removed the faceplate you need a plugin microfilter for the test socket to which you can then connect the router.
on 29-11-2021 11:09 AM
on 29-11-2021 11:00 AM
says not supported format
on 29-11-2021 10:37 AM
Hi spirit1
Would it be possible to post a photo of your master socket on this thread.
on 29-11-2021 10:05 AM
my bt mk4 does not have a test socket for router, only a phone test socket i just checked,
on 29-11-2021 09:50 AM
Hi spirit1
If the connection is now stable then DLM should start to adjust the profile to increase the speed.
Would it be possible to connect the router at the test socket for 48hrs (without rebooting) We can then check the connection stats again on Wednesday to see if DLM has made any changes to the speed/profile.
on 29-11-2021 09:46 AM
no it seems to have stopped, but still slow..
on 29-11-2021 09:45 AM
Hi spirit1
Ok, is the connection still dropping?
