on 07-09-2022 07:29 PM
my router has stopped working and has started flashing orange. Unable to connect from any device.
on 13-09-2022 12:39 PM
Hi Croftierj
Ahh great news 🙂 Thanks for letting us know.
I have also sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 13-09-2022 12:35 PM
@Debbie-TalkTalk oh sorry I thought I had replied to this thread but it must’ve failed to send through! The new router arrived promptly and we’ve had no issues since! Working fab! Thank you 🙂
on 13-09-2022 12:33 PM
Hi Croftierj
How are you getting on, have you received the replacement router?
on 08-09-2022 06:20 AM
Hi Croftierj
The line test is clear so I have ordered you a replacement router for testing.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
on 07-09-2022 08:45 PM
thanks @Skynet_TX . Unfortunately the reset hasn’t worked 😞 so hopefully an agent can look into this tomorrow
on 07-09-2022 08:20 PM
Yes, it could potentially be a router fault, you could try a factory reset (if you haven't already) by holding in the reset switch on the back for over 10 seconds. But if that doesn't help, the team here will be able to look into this tomorrow, if they can't see any other possible cause, and they suspect the router is at fault, they would be able to arrange a replacement for you.
on 07-09-2022 08:18 PM
@Skynet_TX I have done this and it says the service is running fine when it is still flashing orange so clearly it isn’t fine. I work from home so this is extremely important. I think the router itself may be damaged
on 07-09-2022 08:12 PM
Hi @Croftierj,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
