on 14-02-2024 11:34 PM
The router login page address [http://192.168.1.1] is not loading. Currently I have the wifi switched off on my router, to turn it on I have to login to the router to make the change. At the moment it is only possible to access internet via a ethernet cable. Please help. It is urgent as none of the devices are able to connect to the internet with the wifi turn off.
on 16-02-2024 09:01 AM
Hi kumsis
How are you getting on, did you try the factory reset?
on 15-02-2024 07:20 AM
Hi kumsis
Have you factory reset the router using the pin hole reset for ten seconds?
