Help
Joan2
Message 4 of 4
What is the point of having a help line
IF YOU PEOPLE ARE SO SLOW AND UNHELPFUL
3 REPLIES 3
Message 1 of 4
Hi Joan,
Do you still need assistance with this?
Chris-TalkTalk
Message 2 of 4
Hi Joan,
As Keith has said, if you let us know what the problem is we are happy to help 🙂
Message 3 of 4
If you could please explain the problem, then TalkTalk in this forum will try & helpful. They are all UK based & do not work to scripts.
