router speed
Riley321
Whizz Kid
Message 3 of 3
i have a wifi hub black and the speed is not constant, what is the best router
Message 1 of 3
Hi Riley321
Is the speed dropping? If you reboot the router does the speed increase?
Is this happening on both wired and wireless connections?
Message 2 of 3
Which "speed" are you referring to: wired; wireless; sync at the router? I have the same Hub and find it generally performs well, so there may be other issues at play.
