speed problem
Lesman
Whizz Kid
Message 335 of 335
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
334 REPLIES 334
Message 181 of 335
Hi Les,
I'm really glad to hear this and I'm glad to hear that the fault has been resolved and your speeds have improved 🙂 I've chased the My Connection team now about the speed tester issue and I will post back here as soon as they reply with an update.
Michelle 🙂
Message 182 of 335
Hi Michelle
Two days ago, the replacement of a section of the main line (approximately 25 meters) was completed.
There is good news.
The speed returned to normal - about 33 Mbps. It is now possible to check the speed on the TalkTalk website through my account. My neighbor's internet speed has also increased. So the problem was still in the main line cable. I think so.
I hope that my internet problems that have been going on since April last year are finally over.
Thank you for your help.
Les
Message 183 of 335
Hi Les,
Just a quick post to let you know that I've not forgotten your thread and we'll re-check first thing in the morning when we should receive another update from Openreach.
Message 184 of 335
Morning Les,
We've received a further update to advise that further dig work is required to fix a buried joint. We've been advised that the next update is due on 13/03 so we'll check back on this date for a further update for you.
Message 185 of 335
Hi Les
We will re escalate the speed checker issues once the fault has been resolved,
Thanks again.
Message 186 of 335
Hi Debbie
Thank you for the information. Currently, the earthworks are being carried out by Openreach. However, I still can't check the speed through my account. I informed about it on February 23.
Les
Message 187 of 335
Hi Lesman
I've contacted Openreach this morning for an update and they have advised that the engineer will be working on this fault today and further updates will be available on the end of the day.
Message 188 of 335
Hi Michelle
I will wait patiently for the problem to be resolved.
Regards.
Les
Message 189 of 335
Hi again,
I've checked again and there are no further updates and we're still awaiting an update on the dig work. If we don't hear anymore by Monday morning then we can contact Openreach for an update for you.
Message 190 of 335
Morning Les,
No additional updates as yet so I will check again in a few hours.
Message 191 of 335
Hi Les,
The latest update we've received is that dig work is required to resolve this particular fault. No estimated resolution date provided at the moment but it's still in hand with the engineers and we will check again tomorrow for you.
Message 192 of 335
Hi Les,
I'm glad to hear that Openreach have been in touch. I'll check this afternoon to see if we have received an estimated resolution date and will post back with an update.
Message 193 of 335
The engineer said that the problem has not been fixed - there is a need to replace or repair some element on the line. I don't know what, it's technical nomenclature.  Maybe this will be fixed next week.
Les
Message 194 of 335
Afternoon Les,
I've checked again and there are no additional updates as yet and the fault is still with the Openreach line engineer. We'll check this again in the morning and we should hopefully know more by then.
Message 195 of 335
Morning Les,
I've re-checked the fault and I can see that the fault has been assigned to a line engineer this morning. I'll check again this afternoon for any additional updates.
Message 196 of 335
Thanks for testing and confirming. As the line test is still detecting a potential voice fault externally, I've passed this over to Openreach now to complete an external line investigation. A voice fault can affect the broadband connection so we would need to clear this voice fault first. We'll check first thing in the morning for an update for you.
Message 197 of 335
The dial tone is audible but not clear. You can hear gentle noises.
Les
Message 198 of 335
Hi Les,
Thanks for the update. One of the line tests is now showing a possible voice fault. Is there currently a dial tone on the voice service with no noise please?
Message 199 of 335
Hi Michelle
I just checked and nothing has changed. Always the same message.
I received a new cable and checked the speed as well as through the test socket. No changes. The same results on the new and old cable - about 27 Mbps. So there were problems with breakdowns outside my house all the time.
Les
Message 200 of 335
Hi Les,
Has there been any change with the speed tester since my last post please?
