speed problem
Lesman
Whizz Kid
Message 335 of 335
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
334 REPLIES 334
Message 161 of 335
Hi Les,
Thank you. I've re-run the line test and it's now clear. Do you still have the previous router that you could re-connect and we'll run the test again?
Message 162 of 335
Of course. I unplug the router and phone for 20 minutes.
Les
Message 163 of 335
Hi again Les,
Ok thanks for confirming. Would it be possible to remove the router and phone for around 10 minutes so we can re-run the line test again with no equipment connected to the line?
Message 164 of 335
Yes, it is in the test socket all the time
Les
Message 165 of 335
Morning Les,
Thanks for the update. I can see that the connection looks stable but the line test is detecting a potential fault towards the property. Is the router still connected to the test socket at the moment please?
Message 166 of 335
Hi Michelle
I'm sorry that I'm replying only now, but I was away from home all day.
Since replacing the router, the Internet has remained connected all the time.
The speed is about 28 Mbps (it has not returned to the former about 32 Mbps).
I had three situations while working on the Internet in which programs suddenly slowed down significantly, only to return to full speed after a dozen or so seconds. I don't know if it is related to the sudden drop in internet speed or there is another reason.
Should I do anything else or switch the router connection from the test socket to the normal one?
Les
Message 167 of 335
Hi Les,
How has your connection been?
Message 168 of 335
Thanks Les. It can take DLM between 24-48hrs to make changes to the speed if the connection remains stable so I'll check back in with you on Wednesday if that's ok to see how the connection compares and how you're getting on.
Michelle 🙂
Message 169 of 335
Hi Michelle
Currently, the new router is connected via a test socket.
The speed checked on the TalkTalk website is 26 Mbps.
Should I do anything else and how long should I leave the connection via the test socket?
Les
Message 170 of 335
Hi Les,
Ok thanks for the update. Could you try connecting the new router at the test socket and let us know how the stability compares following this. We can then check the broadband speed again.
Message 171 of 335
Keep the set up exactly as it is until staff respond (during the day), @Lesman.
Message 172 of 335
Hi Chris
Can I switch from test socket to normal socket now?
The Internet speed remains at 27 to 28 Mbps - it has not gone back to the previous 30 to 33 Mbps. It works stably - there were no connection drops. I'm still working on an old router.
Can I risk connecting a new router - while working with it, there were connection interruptions . I don't know if the problem was the new router, but after replacing it with the old one, the connection drops disappeared but the speed dropped.
Please let me know what to do next.
Les
Message 173 of 335
OK thanks. Hopefully DLM will move you to a faster profile over the next couple of days
Message 174 of 335
Ok. The router will be connected to the test socket for 48 hours.
I now measured the speed - 25 Mbps to the router and 22 Mbps to the computer.
Measurement taken on the TalkTalk website.
The connection is still normal, it does not interrupt, but the Internet works all the time on the old router.
Les
Message 175 of 335
Could you leave it connected to the test socket for 48 hours and we'll see if the disconnections continue and if DLM moves you to a faster profile. If there's no improvement then we'll probably need to arrange an engineer visit
Message 176 of 335
Hi Chris
The phone works normally, I don't hear anything strange.
Currently, the router is connected to the test socket through a filter.
The speed has not changed.
How long should I leave the router connected like this?
Les
Message 177 of 335
Hi Les,
I can see that your connection has been unstable. Line test is picking up a potential issue. Is your router currently connected to your test socket? Are you experiencing any problems with your telephone service?
Message 178 of 335
Hi Michelle
About three weeks ago, another Internet comedy began. The speed ranged from about 33 Mbps to about 10 Mbps. The internet stopped working and came back on by itself. There were two visits by engineers (after a test on the TalkTalk website - an error was found). After the last visit, the speed was around 28 Mbps and the internet worked normally. Yesterday I started having problems with internet interruptions. About four hours ago, I connected my old router. During all this time, the Internet never stopped working, but the speed dropped to about 23 Mbps - that is, about 10 Mbps as usual. The router that was disconnected worked for about five months, it is not that old.
I don't understand any of this.
What do I do with it?
Please help.
Les
Message 179 of 335
Morning Les,
That's excellent news 🙂 Please let us know if there is anything else we can help with 🙂
Message 180 of 335
Hi Michelle
Speed test and other test functions also started working properly.
The "magic wand" worked and everything works fine.👍🌷
Les
