speed problem
Lesman
Whizz Kid
Message 300 of 300
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
299 REPLIES 299
Message 141 of 300
Hi Chris
The phone works normally, I don't hear anything strange.
Currently, the router is connected to the test socket through a filter.
The speed has not changed.
How long should I leave the router connected like this?
Les
Message 142 of 300
Hi Les,
I can see that your connection has been unstable. Line test is picking up a potential issue. Is your router currently connected to your test socket? Are you experiencing any problems with your telephone service?
Message 143 of 300
Hi Michelle
About three weeks ago, another Internet comedy began. The speed ranged from about 33 Mbps to about 10 Mbps. The internet stopped working and came back on by itself. There were two visits by engineers (after a test on the TalkTalk website - an error was found). After the last visit, the speed was around 28 Mbps and the internet worked normally. Yesterday I started having problems with internet interruptions. About four hours ago, I connected my old router. During all this time, the Internet never stopped working, but the speed dropped to about 23 Mbps - that is, about 10 Mbps as usual. The router that was disconnected worked for about five months, it is not that old.
I don't understand any of this.
What do I do with it?
Please help.
Les
Message 144 of 300
Morning Les,
That's excellent news 🙂 Please let us know if there is anything else we can help with 🙂
Message 145 of 300
Hi Michelle
Speed test and other test functions also started working properly.
The "magic wand" worked and everything works fine.👍🌷
Les
Message 146 of 300
Hi Les,
I'm really glad to hear this and I'm glad to hear that the fault has been resolved and your speeds have improved 🙂 I've chased the My Connection team now about the speed tester issue and I will post back here as soon as they reply with an update.
Michelle 🙂
Message 147 of 300
Hi Michelle
Two days ago, the replacement of a section of the main line (approximately 25 meters) was completed.
There is good news.
The speed returned to normal - about 33 Mbps. It is now possible to check the speed on the TalkTalk website through my account. My neighbor's internet speed has also increased. So the problem was still in the main line cable. I think so.
I hope that my internet problems that have been going on since April last year are finally over.
Thank you for your help.
Les
Message 148 of 300
Hi Les,
Just a quick post to let you know that I've not forgotten your thread and we'll re-check first thing in the morning when we should receive another update from Openreach.
Message 149 of 300
Morning Les,
We've received a further update to advise that further dig work is required to fix a buried joint. We've been advised that the next update is due on 13/03 so we'll check back on this date for a further update for you.
Message 150 of 300
Hi Les
We will re escalate the speed checker issues once the fault has been resolved,
Thanks again.
Message 151 of 300
Hi Debbie
Thank you for the information. Currently, the earthworks are being carried out by Openreach. However, I still can't check the speed through my account. I informed about it on February 23.
Les
Message 152 of 300
Hi Lesman
I've contacted Openreach this morning for an update and they have advised that the engineer will be working on this fault today and further updates will be available on the end of the day.
Message 153 of 300
Hi Michelle
I will wait patiently for the problem to be resolved.
Regards.
Les
Message 154 of 300
Hi again,
I've checked again and there are no further updates and we're still awaiting an update on the dig work. If we don't hear anymore by Monday morning then we can contact Openreach for an update for you.
Message 155 of 300
Morning Les,
No additional updates as yet so I will check again in a few hours.
Message 156 of 300
Hi Les,
The latest update we've received is that dig work is required to resolve this particular fault. No estimated resolution date provided at the moment but it's still in hand with the engineers and we will check again tomorrow for you.
Message 157 of 300
Hi Les,
I'm glad to hear that Openreach have been in touch. I'll check this afternoon to see if we have received an estimated resolution date and will post back with an update.
Message 158 of 300
The engineer said that the problem has not been fixed - there is a need to replace or repair some element on the line. I don't know what, it's technical nomenclature.  Maybe this will be fixed next week.
Les
Message 159 of 300
Afternoon Les,
I've checked again and there are no additional updates as yet and the fault is still with the Openreach line engineer. We'll check this again in the morning and we should hopefully know more by then.
Message 160 of 300
Morning Les,
I've re-checked the fault and I can see that the fault has been assigned to a line engineer this morning. I'll check again this afternoon for any additional updates.
