on 11-03-2022 01:52 PM
was going to switch provider to shell because of the terrible speed I was getting from TalkTalk
shell promised 17Mbs maybe 36 Mbs but then TalkTalk phoned my mobile
and said I would never get 36 but possibly 17 using my current phone line
also said if I canceled shell I would get
new cheaper 12 months contract 17 Mbs
new better router
well new cheaper price has not started yet although the package shows new
speed is still miserable 9 Mbs like before
and no new router just appalling broadband speed.
fiber is supposed to be coming but no one knows when
I am registered with openreach.
on 15-03-2022 11:54 AM
Yes, in that case it does appear to be a fault with the internal wiring or an extension socket. So if you move the master socket and don't reconnect the extension socket then it should be OK
on 15-03-2022 11:45 AM
fitted panel back to bt socket and plugged in router to the same socket with microfilter
landline phone disconnected
speed dropped back to 12 Mbs so I guess its wiring or extension socket
the only device plugged in is a router.
on 15-03-2022 10:09 AM
Yes, not only has your speed improved but the error count has dropped as well 🙂
If there's a big difference with your router connected to the test socket then it really indicates that there's a problem with your extension wiring/sockets or a device that was connected but isn't now - possibly your telephone. You could try putting the master socket faceplate back on but leave your telephone unplugged just to rule out your telephone causing any issues
on 15-03-2022 09:55 AM
tested 24 hours speed good 18 Mbs big difference.
if BT fit the new master socket in a convenient location
will I still get the same speed as when I connected to the test socket?
on 14-03-2022 10:44 AM
OK thanks Keith, I've restarted the optimisation process so we'll see if there's any improvement over the next 24 hours
on 14-03-2022 10:41 AM
not much space for landline wires hanging out of master socket
the router on the floor right in door way but I have a mobile
which I use for most calls.
on 14-03-2022 10:39 AM
Thanks Keith. I'll restart the optimisation process - are you able to connect your telephone to master socket?
on 14-03-2022 10:38 AM
speed has increased to 14 Mbs
on 14-03-2022 10:35 AM
ok so no landline for 24 hours then
the router is now moved to the main bt socket and the faceplate is removed.
on 14-03-2022 10:18 AM
We would really need to test with your router connected to the test socket. To access the test socket you would need to remove the master socket faceplate and this would disconnect the extension socket
on 14-03-2022 10:08 AM
would I need 2 micro filters because was going to router at bt master socket (1 filter)
and leave landline plugged in extension socket (2cnd filter).
don't think bt master socket has a built-in filter.
on 14-03-2022 10:04 AM
ok yeah, I can fit at the master socket temporarily would be awkward because it is by a narrow entrance and would be kicked over easily.
The only alternative I can see is to get bt to move the master socket to the living room.
on 14-03-2022 09:52 AM
OK thanks. Is there any way that you could connect the router to the test socket and leave it there for 24 hours and we'll see if there's any improvement
on 14-03-2022 09:47 AM
Bt socket I have NTE 5C by the front door entrance to the property but this is not used as it's not a suitable location
in the living room, I have an extension socket with a landline phone and router plugged in microfilter.
on 14-03-2022 09:16 AM
Hi keitht1958,
Thanks for the update. Could you just take a look at the following help article and let me know which type of master socket you have - Your guide to main phone sockets - TalkTalk Help & Support
on 14-03-2022 09:04 AM
ok seems better now was getting 9 Mbs but since optimization router settings says 13 Mbs
could not get Talk Talk speed check to work ethernet or wi-fi so did a google speed check that said 10 Mbs.
Sunday speed went to 3 Mbs so had to reset the router then it went back to 10 Mbs
Monday speed went to 5 Mbs so had to reset the router twice 1st time no change, 2cnd reset was back to 10 Mbs.
I usually have to reset the router once a month to keep getting reasonable speed.
with the new contract, I was promised a new router but nothing has arrived yet.
but the speed seems better although not getting 17 Mbs as promised,
on 11-03-2022 03:50 PM
OK, I've started the optimisation process. Can you bump the thread on Monday and we'll see how it's getting on
on 11-03-2022 03:49 PM
OK, click on See Internet Settings > Manage Advanced Settings > continue> System info > DSL info
Take a screenshot, do not try to attach as a file, use the camera/image icon in the toolbar.
on 11-03-2022 03:38 PM
We can try resetting the line management system (DLM)
that's fine.
on 11-03-2022 03:36 PM
screenshots would only let me attach 1 screen I have 2 jpegs.
