uefa.tv live stream not working
stevefowell
Message 30 of 30
uefa.tv live stream (of u-21 euros matches) just shows a continuous spinning wheel, both on the website on my laptop and on the app on Android 11 phone. Other uefa.tv videos (such as match highlights) stream ok. I have a Sagemcom 5364 router.
I have tried other wifi, such as from a hotspot from another mobile and using my son's router (which isn't TalkTalk). Both these streamed the live action with no problems.
Any ideas?
Steve
29 REPLIES 29
Message 1 of 30
Thanks for the update and I'm glad to hear that you've been able to resolve this.
stevefowell
Message 2 of 30
Hi Chris
I followed your network engineer's advice and checked the network connections. The majority of connections were from akamaized.net which is the content delivery network Akamai. So I added this to the list of allowed sites in Kids Safe. This however didn't change anything. So I looked a bit further and noticed that there were occasional connections to imggaming.com. I think that this is related to the IMG Arena sports data company. So I added imggaming.com to the list of allowed sites and this has fixed the problem. Although I can see why Kids Safe objects to such a domain I have no idea why such nomenclature is being used on the site since there appears to be no gaming or gambling related content shown to the user. Incidentally, I am disappointed (but not surprised) that uefa.tv support hadn't picked up on this and told me about it. I would add that I wouldn't be surprised if there were other live sports streams that use IMG's services and that there is a potential for Kids Safe to block those streams as well.
So, all's well that ends well. Please thank your network engineer on my behalf for pointing me in the right direction.
Steve
Message 3 of 30
Hi Steve,
I've received an update, dicelaboratory.com is flagged in the games and gambling categories.
They've said - If you are trying to keep these categories on and view the streams you would need to identify the other domains this is making use of and whitelist those as well. In a similar way to using inspect, you can open the developer tools and select the Network tab which shows the connections the webpage makes when it is connecting to the stream.
They go on to say, there isn't a fault here, HomeSafe is working as it should do
Hope this helps
Message 4 of 30
Thanks Steve, I've passed your comments on, I'll let you know when I receive an update
stevefowell
Message 5 of 30
Hi Chris
Ok, with "Gambling" and "Games" not blocked I played the live stream on my Chromebook. The URL at the top of the page is still uefa.tv. However, I did an "inspect" on the page and it looks like the stream is possibly being played with a video player called Dice Video Player. Also the image that is displayed prior to the video looks like it comes from the domain dicelaboratory.com.
So, I blocked "Gambling" and "Games" again and allowed dicelaboratory.com. This resulted in the image now being displayed (instead of nothing before) but the video still did not play.
Can your network engineer do what I have done and see if he/she concurs? The suspicion is of course that the word "dice" here is causing the problem. But I can't allow Dice Video Player to see if that fixes it. How would I do that? But if that is the culprit presumably other sites on the internet that use the same player will be affected.
Steve
Message 6 of 30
Sorry, I don't know how you would see it in the app. If you can't find the domain, uefa.tv support team may be able to help
stevefowell
Message 7 of 30
Hi Chris,
Yes, my thoughts too. I will check to see if I can see a domain name on my Chromebook when the matches start tonight. But how would I check a domain name if viewing in the app?
Steve
Message 8 of 30
Hi Steve,
One of our network engineers has had a look at this, he's confirmed that uefa.tv isn't in any blocking category which makes sense as you can access the website. He says that the live stream may be hosted on a different domain name and if you could let us know which domain name it's hosted on he can check if that is being blocked
Message 9 of 30
OK thanks Steve. (sorry, no there's no reference number)
stevefowell
Message 10 of 30
Thanks Chris, but please remember it can only be replicated when there is a live match on. There are still some u-21 matches left and there are some u-19 matches coming up. Also, a reminder that, even with uefa.tv on the allowed list, the issue still exists.
Will I get a reference number for the escalation?
Steve
Message 11 of 30
Ok thanks, we'll look into it, I'll let you know when we have an update
Message 12 of 30
My bad. So just switch it off when you want to watch uefa.tv? Maybe try the FileSharing site setting also? It might be that because their sponsors are laden with booze and betting companies that this is why it is being screened out. It is a fairly blunt tool when all is said and done and may have unintended consequences accordingly. It is not compulsory, you do have a choice.
stevefowell
Message 13 of 30
Hello ferguson
All that has been done, please read all the posts.
Steve
Message 14 of 30
OK, I don't use any of the HomeSafe solutions myself, but is it not possible to add the streaming site in question to the exception list? Alternatively, try switching KidSafe off temporarily and see if it works then.
stevefowell
Message 15 of 30
Hi Chris and Michelle,
Ok, I did some further tests during a live match which uefa.tv was streaming tonight.
I have found out that when either of the categories "Gambling" or "Games" is selected to be blocked the live match cannot be streamed. So the live stream must be being erroneously considered to be related to gambling or gaming.
I also tested this with the same result on a Linux machine so I have the same problem on three different devices.
Are you able to escalate this for me or should I raise a complaint to TalkTalk?
Steve
stevefowell
Message 16 of 30
Hi Chris
Surely, to give more of an insight as to whether this issue is unique to me, it would be worthwhile trying to replicate it (that being so easy to try). I don't think that, because no one else has reported this issue, that you should assume that the fault lies with my devices. I have a Chromebook with up-to-date software and an Android 11 mobile which is also up-to-date. I have no other internet issues and have had no problems streaming football from BT Sport and Sky Sports. Why would my devices be responsible for stopping a stream with Kids Safe on but play the stream with Kids Safe off? That would, in any case, imply that Kids Safe is interacting with my devices.
With Kids Safe on, when I try and stream the u-21 matches on my Chromebook, nothing happens; I just get a blank window. When I try in the app on my mobile I just get a spinning wheel. There is no video coming through at all. I get no error messages.
I can also try and stream the matches on Linux and on Windows 10. I will do that on Saturday although I can't see that it would make any difference. But I am open to being amazed.
My personal hunch is that Kids Safe is picking up on something within the stream supplied by the content distribution network used by uefa.tv and is erroneously blocking the stream based on that data.
But let's see if I can narrow this down to a particular category when the matches are streamed on Saturday.
Steve
Message 17 of 30
Hi Steve,
If there's a general problem with uefa.tv then we would expect other customers to be reporting the same issue so the information about the categories will be useful
Could I just ask, do you experience the same issue on more than one device when connected to your TalkTalk router?
Do you get an error message when you can't stream?
stevefowell
Message 18 of 30
Yes, I will report my findings back to you.
Surely, however, the first step for TalkTalk is to replicate the issue. uefa.tv will also be showing live matches from the u-19 competition up until July 16th so there will be time to replicate in the next couple of weeks.
Steve
Message 19 of 30
Hi Steve,
Thanks for the information. Yes it would be useful to find out if a specific category is causing the issue so if you could let us know how you got on, on Monday, that would be great
stevefowell
Message 20 of 30
Hi Michelle
Yes, that's correct, but only the live streaming from the site; I don't have any problems with the rest of the site.
Other than the live streams of matches I can access everything on the uefa.tv site, including on-demand video, whether or not Kids Safe is switched on and whether or not uefa.tv is added to the inclusion list. Basically, other than the live streams of matches, all of the uefa.tv site (and the uefa.tv app) work completely fine irrespective of the Kids Safe settings,
As I found out yesterday, if Kids Safe is switched off I can also access the live streams of matches.
But when Kids Safe is switched on (with the settings I had) I cannot access the live streams of matches. The live stream doesn't start at all. On my phone it just displays a whirling circle; on my laptop nothing happens at all. If Kids Safe is then switched off the live matches are shown straight away.
It follows that Kids Safe is blocking a live football match!
On Saturday (when the next live matches are shown) I will try and ascertain if a single particular blocked website category is responsible.
I am sure that this issue will be easy to replicate but please bear in mind there are not many matches left in the current uefa tournament.
Steve
