voip
Stephenkilminster
Message 2 of 2
i have fibre 35. i just want to use a voip phone. how do i set this up?
1 REPLY 1
Divsec
Message 1 of 2
Hi @Stephenkilminster I haven't noticed talktalk offering a VoIP package for fibre 35 so you would be looking for a VoIP service supplier on top of your tt package. Just googling VoIP will bring you lots of them (some American thrown in) obviously none are free.
You'll then likely need an adapter, loads to chose from. Good news is your existing landline phone or dect system should work.
Downside is you are unlikely to be able to keep your existing phone number.
I went down this rabbit hole and decided my mobile phone was my solution as I was already paying for it.
If you were able to upgrade to a faster true fibre tt offering things would be different.
Sorry for the shoulds and woulds and coulds
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
