Broadband dropping connection
on 25-02-2024 08:57 AM
Message 16 of 16
Hi, I have a continuing problem of loosing connection, openreach have been and said there was a line fault and supposedly been rectified, I have contacted talktalk support and gone through the usual checks again, master socket 5C MK4, turn router off etc, they said they had loaded some software on the router, turned it off for 20 minutes (DG8041W), Still dropping out yesterday afternoon and most of the evening, I gave the talktalk agent the times etc, the router flashes amber when connection drops, when I try to log on to talktalk to test, I just get my fault report and it says they may be a problem? The agent say's it will be ok, it's definitely not! Any help would be appreciated
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
15 REPLIES 15
on 07-03-2024 06:29 AM
Message 1 of 16
Hi chrisncc1701
That's great, thanks for letting us know 🙂
The WIFI optimisation should now remain off (unless the router is factory reset - pin hole reset)
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-03-2024 09:24 PM
Message 2 of 16
Hello, it's all working ok now the optimisation has been turned off, will it remain off if the router receives an update?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-03-2024 06:45 AM
Message 3 of 16
Hi chris,
Please let us know how your connection compares 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-03-2024 05:33 PM
Message 4 of 16
Thank you 👍🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-03-2024 10:27 AM
Message 5 of 16
Hi chrisncc1701
Apologies. I've now switched the WIFI optimisation off so it should now remain on your chosen WIFI channel.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-03-2024 10:13 AM
Message 6 of 16
Hello. I think it is going to be ok, broadband doesn't drop any more. But the problem now is, I manually change WiFi channels to avoid neighbours WiFi and congestion, then it's fine, but the router changes channels after some time to unusable ones with interference?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-02-2024 12:47 PM
Message 7 of 16
Hi chrisncc1701
Thank you 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-02-2024 12:44 PM
Message 8 of 16
Thank you, I will
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-02-2024 12:35 PM
Message 9 of 16
Hi chrisncc1701
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-02-2024 12:27 PM
Message 10 of 16
Yes that would be fine, thank you, I'll send the other back
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-02-2024 07:40 AM
Message 11 of 16
Hi chrisncc1701
I'm really sorry about this.
I will need to send a different make and model of router to resolve this issue (Sagemcom WIFI hub) Are you happy for me to arrange this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2024 04:19 PM
Message 12 of 16
Ok. Thank you, I'll wait and see what happens 👍
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2024 02:55 PM
Message 13 of 16
Firmware V1.08 is very unstable. I have asked one of TalkTalk's support to pick your thread up and decide the best way forward.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2024 02:34 PM
Message 14 of 16
Hi, it says hardware version I.1.01 and software version v1.08t
Device version DG8041W-2.T5
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2024 01:19 PM
Message 15 of 16
What firmware is on the DG8041W?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
