Broadband poor
Alfieruss1
Message 4 of 4
Wifi very poor since fibre fitted
3 REPLIES 3
Message 1 of 4
Hi Alfieruss1
Do you still need help with this?
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 2 of 4
Hi Alfieruss1
Message 3 of 4
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
