Cannot login to my router Admin
eileenfionabrown
Message 7 of 7
I have reset my router and entered the default username and password, I have tried multiple browsers and verified my IP address, yet, my pass/user are received as incorrect.
Any help would be appreciated,
6 REPLIES 6
Message 1 of 7
Hi eileenfionabrown
I'm glad to hear that this has been resolved, thanks for letting us know.
eileenfionabrown
Message 2 of 7
I've managed to solve the issue, consider this matter closed.
eileenfionabrown
Message 3 of 7
Yes, I just said?
Message 4 of 7
Have you done a factory default of the router's configuration to ensure that the password has been reset to the documented one? This can be done by pressing & holding the small reset switch for about 10 seconds, while it is turned on.
Message 5 of 7
Yes, don't worry. I am using the router admin and password. I am NOT using the wifi credentials.
Message 6 of 7
Are you using the router password (username is admin) quoted on the label on the rear of the router and not the WiFi credentials?
