Help with Router HG635
GAF44
Message 7 of 7
Wifi is super slow and frequently drops out. Am trying to work out if we need a new router or there is another fix to improve it?
Anyone have any ideas? I can't remember when the router is from so not sure how old it is and can't seem to find any details in the account history.
Any tips gratefully appreciated.
6 REPLIES 6
Message 1 of 7
Hi GAF44
Have you received the router?
Message 2 of 7
Hi GAF44
Please let us know how the connection compares.
Message 3 of 7
Have tried that before, yes. Be great if you could send a replacement. Thank you!
Message 4 of 7
Hi GAF44
Thanks for updating your Community Profile 🙂
Can I just check, have you also factory reset the router using the pin hole reset for ten seconds?
If you have already tried this then please let me know and I can send a replacement router.
Thanks again.
Message 5 of 7
Thanks Debbie. Have done.
Message 6 of 7
Hi GAF44
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
