Connected no internet
paulcheshire
Message 4 of 4
Can "connect" but no internet.  Any ideas?
3 REPLIES 3
Message 1 of 4
Morning paul,
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 4
When your internet goes down, it doesn't stop you from connecting to the router. I suspect that's what's happening here. Log into your router (maybe at http://192.168.1.1/ - check your instructions) and it will tell you if it's currently connected. to the internet
Billx
Insightful One
Message 3 of 4
You say that you can  'connect', but what are you connected to, other than to the internet?
If you are connected to the internet, then there IS internet.
Bill
