Digital Voice and eero
Teach13
Message 22 of 22
Under my new fibre package Talktalk sent me an eero today to replace my existing router. I have set it up and now see that there is no connection for my landline (digital voice). Do I need an adapter?
Thank you
21 REPLIES 21
Message 1 of 22
Hi @Teach13
Apologies, would you like me to take a look at this for you?
Message 2 of 22
Yes thank you. The blue light for the phone flashes on and off. I have received phone calls on the landline but cannot phone out. Not too worried about this I only use my mobile to phone out.
Message 3 of 22
Message 4 of 22
Profile updated
Message 5 of 22
@Cervelo2000, the error may be that you have not picked a label to help the message reach the right department. See below the message area in your new topic to select a label.
Posting on another customer's thread really confuses the issue.
@Chris-TalkTalk appears to be  replying to the OP, @Teach13.
Message 6 of 22
OK thanks, so what exactly is the issue?
Message 7 of 22
Ok, thanks, Chris
Message 8 of 22
OK, could you update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 9 of 22
As a newcomer to the forum I’m not familiar with it. I was trying to reply via myiPhon e so that might have been the problem. But as you appeared to have solved Teach 13’s problem I thought this might be the easiest way to sort it.
Message 10 of 22
Yes
Message 11 of 22
So you're clicking on the blue 'start a topic' button, entering something in the subject field and in the body, then clicking the blue post button?
Message 12 of 22
I have tried to post as you suggested but getting a message which reads: “Correct the highlighted errors and try again” so pressing thePost button does not work. Any suggestions?
There are no highlighted errors!
Message 13 of 22
Hi Cervelo2000,
If you need assistance can you please start your own thread/topic in the appropriate support section - Help with your service - TalkTalk Help & Support
Cervelo2000
Message 14 of 22
I have just discovered the same problem. A new eero but nowhere to plug in my phone line. If any TalkTalk staff monitor this can they make contact with me please
Message 15 of 22
Hi Teach13.
I've ordered the digital voice adapter, it should be with you within a couple of working days but please allow up to 5 working days for delivery
Message 16 of 22
Profile updated.
No, I did not receive a digital voice adapter.
Thank you
Message 17 of 22
Thanks for confirming. Did you not also receive a digital voice adapter? (DVA)
  • Name
  • Telephone number or Account number
Message 18 of 22
Fibre 150 and Voice Package
I have another problem...my laptop picks up WiFi no problem but my iPhone says I am connected without internet.
Thanks for your help.
Message 19 of 22
Good morning,
What FTTP package did you sign up for please?
Teach13
Message 20 of 22
Oh great, I am on City Fibre...thank ypu for your response
