Should I select Rotating or fixed IP on split network
Raychel
Message 3 of 3
I have a split network on my router 2.4/5ghz as I have smart devices.  Is it best to have both on a rotating or fixed ip and will this affect my smart devices if I do.  Any help would be appreciated as not that technical.  Thanks
Message 1 of 3
IP address allocation is done after a wireless device connects to the network. The customer can choose to use normal DHCP allocation, DHCP Reserved, or static IP addresses.
Message 2 of 3
Good morning,
@KeithFrench - Would you be able to offer any advice please?
