Drop outs and slow speed
Vader2004
Whizz Kid
Message 20 of 20
We've got fibre broadband and lately we've been getting drops in the connection, it's been happening for a while now, there was works going on putting in new cables around the corner from us, but that is now complete, when line tests are run it's showing no errors, but the line speed has dropped below 110mb gets as low as 24mb, could some look at it for us?
I've rebooted the router and modem, replaced all cables, no phone is plugged into the sockets and no other sockets are in the house just the main one, I've got a spare modem and have swapped over to it yesterday, speed is higher but varying?
Dave
Be a better Human!
19 REPLIES 19
Message 1 of 20
Morning Dave
Yes of course. Please let me know if the speed or connection does drop again.
Vader2004
Whizz Kid
Message 2 of 20
Hi Debbie
Sorry for the slow reply, I've been away for work, I've tested it a couple of times at it seems to be running around 112mbs at the moment, maybe we can leave it for a bit and see how stable it stays
Thanks for your help
Dave
Be a better Human!
Message 3 of 20
Morning Dave
I've checked and I can see that the sync speed hasn't increased.
Would you like me to arrange an Openreach engineer visit to investigate further?
Message 4 of 20
Morning Dave
The sync speed is showing at just under 99mb.
I will check this again on Friday.
Vader2004
Whizz Kid
Message 5 of 20
Hi Debbie
The line seems to be stable so far, the speed is slightly better but is still under 100mb, hopefully it will increase a bit more over this week.
Dave
Be a better Human!
Message 6 of 20
Morning Dave
Thanks for letting me know 🙂
I've checked your connection stats this morning the connection does appear to be more stable and sync speed has started to increase.
Vader2004
Whizz Kid
Message 7 of 20
Hi Debbie
I've just finished swapping back over to the other fiber modem, the speed is a little quicker, also tested a few cables from the main box to the modem, I think I've got the best setup not, we can see the speed syncs up now
Dave
Be a better Human!
Vader2004
Whizz Kid
Message 8 of 20
Hi Debbie
Sorry, for the slow reply
I believe it has been stable, the speed is a little slower, I might just try the original fiber modem on again and we can check if it makes any difference I'm a couple o days time.
Dave
Be a better Human!
Message 9 of 20
Morning Dave,
How has your connection been?
Message 10 of 20
Hi Dave
Is the connection still dropping?
I can see that the sync speed has dropped slightly lower since yesterday.
Message 11 of 20
Hi Dave
Great, thank you 🙂
I will check again later this afternoon and I will post back on this thread.
Vader2004
Whizz Kid
Message 12 of 20
Hi Debbie
Sorry for the late reply, no problem I never usually turn off the router off, I'll make sure noone else turns it off
Dave
Be a better Human!
Message 13 of 20
Hi Dave
As the connection has been dropping this will affect the speed. DLM will reduce the speed to try and stabilise the connection.
Please can you keep the router powered up (without rebooting) and I will check the connection stats again tomorrow afternoon to see if the connection is remaining stable.
Once the connection is stable then DLM should start to change the profile again to increase the speed back to what you were previously receiving.
Thanks again
Vader2004
Whizz Kid
Message 14 of 20
Hi Debbie
On Sunday morning it had dropped out, I did all the changing of the cables and swapped over the fiber modem, we have been away for the most of the time on Sunday afternoon and Monday, I don't think we've had any drops since then unless you can see any for yesterday, hope it will settle as the work the was being done around the corner from us has been completed, maybe if you can see what's affecting the speed as it seems to go up and down, it was stable for a long time before.
Dave
Be a better Human!
Message 15 of 20
Hi Dave
Thank you 🙂
The line test is clear but I can see a high number of re connections on the line.
Has the connection dropped since the other router was connected?
Vader2004
Whizz Kid
Message 16 of 20
Hi Debbie/Chris
Sorry, I've updated my profile there now
Dave
Be a better Human!
Message 17 of 20
Hi Dave
I'm unable to locate any details with the landline number in your Community Profile.
Please can you add your TalkTalk account number to the Private Notes section of your Community Profile.
Vader2004
Whizz Kid
Message 18 of 20
Hi Keith
That's great, thanks
Dave
Be a better Human!
Message 19 of 20
