Eero Hubs
Evbama
Message 3 of 3
how do you get the 2nd hub working, I have connected one to the cable out the fibre box which is downstairs, the plan was to put the other upstairs but does it also need the cable out the fibre box?
Chris-TalkTalk
Message 1 of 3
Hi Evbama,
I can see that fr8ys has pointed you in the right direction. If you need any further assistance please let us know
Message 2 of 3
No, it's done wirelessly.
Instructions can be found here
https://community.talktalk.co.uk/t5/Articles/Add-or-remove-eeros-from-your-network/ta-p/2766834
