on 22-01-2025 11:52 AM
Hi.
I'm trying to get my eero6 mesh set up, but the default ip address for the router is 192.168.4.1.
I have 2 devices that I want to connect, they don't have dhcp and have addresses in the 192.168.1.x range (old router had 192.168.1.1 IP address).
How can I get out of this, as I can't seem to change the router's IP, and I can't see my 2 devices to change theirs?
on 22-01-2025 12:58 PM
Yes, you can set the eeros to use the 192.168.1.0/24 network like old TalkTalk routers.do this.
To change this in the app:-
Tap Settings from the Home page, then use the DHCP & NAT option to access IP details.
Select Manual IP, then set the IP address prefix to 192.168.0.0 and input the IP address range.
Typical settings are:-
Subnet IP: 192.168.1.0
Subnet mask: 255.255.255.0
Starting IP: 192.168.1.10 (anything from 192.168.1.2)
Ending IP: 192.168.1.254
Like this, the router will allocate itself the address 192.168.1.1.
Now click the Save button at the top right of the window and a message will be displayed saying that the eero needs to reboot. Accept this & wait until it has done this.
on 22-01-2025 12:19 PM
