FTTP installation
DukeEric
Message 2 of 2
Everything I have read says I need a double plug socket available, I think one to plug in the ONT and one to plug in the router. I only have a single plug socket available. Can I use a simple two or three way plug adaptor?
1 REPLY 1
Divsec
Message 1 of 2
Hi @DukeEric yes!
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
