Fibre 65 Running At 4mbps????
slwukuk
Message 38 of 38
As the subject says.  We noticed an engineer in the lampost outside our house, and ever since our Fibre 65 is really really poor (could be a coincidence mind).  Connection is poor on any and all household devices connected to it.  I have tried splitting the connection and it is no better on 5g or 2.4g, nor is it any better upon trying different channels. :o(
Any advice would be great.
37 REPLIES 37
slwukuk
Message 21 of 38
I now have a dial tone on the house but can't hear speaking nor can my speaking be heard back, where as previously I didn't even get a dial tone.
Message 22 of 38
Thanks for confirming. I've re-run the line test now which is now detecting a potential fault. Can I just confirm, is there currently any noise on the voice service? If the voice service is ok then I'll re-raise this as a broadband fault to Openreach again.
slwukuk
Message 23 of 38
It has been up and down quite a lot since the engineer was out.  Definitely faster but fluctuating greatly yet🤞🤞🤞
Message 24 of 38
Just checking back in to see how you're getting on?
Message 25 of 38
Hi slwukuk
Openreach have now closed the fault. Is everything working ok now?
Message 26 of 38
Hi slwukuk
The fault is now showing as assigned to a line engineer this morning, we should hopefully have further updates later this afternoon.
Message 27 of 38
No problem, yes it's always worth having one hanging around for testing purposes 🙂
slwukuk
Message 28 of 38
Thanks again mate (at least my Mam still had a house phone to borrow) 🤭🤭🤭
Message 29 of 38
No problem. I've raised it as a non-appointed task so Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
slwukuk
Message 30 of 38
Thanks 👍
Message 31 of 38
OK thanks, I'll pass this over to Openreach for further investigation
slwukuk
Message 32 of 38
There was a noise, but it didn't sound like a dial tone at all.
Message 33 of 38
Thanks for trying this, is the line completely dead, no dial tone?
slwukuk
Message 34 of 38
Borrowed a phone and it isn't working in either port I can plug it into (that's including the one where I needed to remove the screws/cover).  No incoming or outgoing calls could be made.
Message 35 of 38
Hi slwukuk,
Is there any way that you could borrow one from a friend or family member, just to test with?
slwukuk
Message 36 of 38
We don't have a landline phone I'm afraid
Message 37 of 38
Hi slwukuk
The line tests have detected a potential fault with the landline service.
Do you have a phone connected? Is the landline working ok?
