Fibre 65 speed drop
on 25-05-2023 06:08 PM
Message 11 of 11
Until recent my broadband speed has stayed at a steady 70mbps. Last few months this has now dropped down to 45mbps. I have contacted talk talk and line checks and tests have been done and no issues have been found. All speed tests have been done with wired devices. Tried several routers to check connection and no difference in speeds. It really feels like talk talk is throttling my service. I have checked with other suppliers and they confirm I should receive approx 70mbps on my line. Other than the slow speeds my service is stable.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
10 REPLIES 10
on 01-06-2023 08:39 AM
Message 1 of 11
I'll send you a PM for some further details.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-06-2023 08:37 AM
Message 2 of 11
I fear this is the only option left. My only concern with that is I’m told if the come out and no fault can be found I will be charged for the visit. Talk talks own tests find no fault with the line..
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-06-2023 08:24 AM
Message 3 of 11
As you have tested other routers also, and the speed is below guaranteed, then the only option is to arrange an engineer. Would you like to progress to this now ?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2023 08:15 PM
Message 4 of 11
The speed to your router is showing as below the guaranteed minimum, so I am sure that the support team will investigate further when they pick this up again.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2023 07:59 PM
Message 5 of 11
Hi. I tried powering off the router for 45 minutes. After restart I returned to the talk talk speed test and the results are pretty much the same as they have been. (Picture attached).
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2023 01:32 PM
Message 6 of 11
all tests are clear and router is in sync at 49mb, with the DLM profile showing at 80/20, so no visible issues showing.
Try powering down the router for 30 minutes to start a new session, then try a new speed test. Try the TalkTalk speed tester, then try Sam Knows Speedtest for comparison.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 31-05-2023 01:14 PM
Message 7 of 11
Hi. I have completed my profile. My download speeds are still at 45mbps. This is still far below the 54mbps guaranteed speed I was given years ago when I signed up for the service and a lot below the average 70mbps I was getting before this issue began. Line tests have come back as no line fault found and other than the speed drop my service works without issue. I’m just trying to find out why the big drop in download speeds. I have attached a picture of the speeds I’m currently receiving.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-05-2023 07:09 AM
Message 8 of 11
Do you still need assistance with this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-05-2023 06:27 AM
Message 9 of 11
- Name
- Telephone number
- Alternative contact number
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-05-2023 08:48 PM
Message 10 of 11
Is the sync speed also low or just the throughput?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
