Flashing orange light on Sagemcom-FAST5464 router and no connection
attilla
Message 15 of 15
Hi, looking at previous posts it seems that I am not the only with this problem, but I have no internet and therefore no work!
The router flashes orange for about 45s then flashes slower for about 45s and then repeats. I have tried resetting the router but this does nothing. The fibre connection box has 3 green lights and then 4 when the router cable is connected and I have tried changing the cable as well.
Any help/advice would be greatly appreciated - thank you.
14 REPLIES 14
Message 1 of 15
Just checking back in to see if your connection has been ok over the last few days?
Message 2 of 15
OK thanks. To be honest I don't know what the fix is, I've checked the notes but can't see anything. If you do experience any further problems just let us know
Message 3 of 15
13.25
Message 4 of 15
Hi Simon,
Glad to hear it's working again. What time did you receive the message?
Message 5 of 15
Hi Chris
Yes the router is now working again thank you - came back on about 1hr ago.
I received a test message saying that "a solution had been applied" - what solution had been applied please?
Simon
Message 6 of 15
Sorry but could you confirm that it's still not working because the router appears to be connected now
Message 7 of 15
Hi Chris
ONT and router plugged back in - all lights on ONT green and router flashing amber as before - no change
Simon
Message 8 of 15
Thanks Chris, I will try that.
Message 9 of 15
Hi attilla,
Can you switch the ONT and router off and leave them off for at least 30 minutes, then switch back on and retest. Please let us know how you get on
Message 10 of 15
Sorry to chase, but can anyone help me with this please?
Message 11 of 15
Hi Michelle
At the ONT all lights are green and when the router is removed the fourth light (ethernet) goes out.
Message 12 of 15
Thank you. Can I just check, are you able to connect at the ONT wired with the router removed to see if this works? This will help us rule out if the issue lies with the router or with the service coming into the property.
Message 13 of 15
Hi Michelle
I have updated my profile but am not sure what you mean by "Once you've updated your profile please post in your topic to confirm it's updated"
Not very good at this - sorry!
Message 14 of 15
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
