on 17-12-2024 08:52 PM
My home hub router isn’t pushing a good Wi-Fi signal as good as it used to,it gets very weak when your more than 6-8 feet away,used to be strong up to 30 feet or more,had it a few years now,so I’m thinking I need a new one,will I have to pay? I’ve been with talk talk for years so I’d hope they wouldn’t charge me,please help,Rusty
on 17-12-2024 10:02 PM
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
