Router not working
Bruceshaw
Message 33 of 33
Hello
having issues with my WiFi router, keeps cutting out after every 30 minutes (no connection) power cycling the router restores connection but not for long
having to power cycle it at least 10 times a day.
seen other people post similar issues and a new router has sorted the problem
would a member of talktalk staff be able to send me a new router tried getting through on the online chat but don’t seem to get a response?
also router constantly shows a white light which indicates all should be ok even when the connection stops
nothing has changed in the household to make it stop working and tried line checks on website which state the line is all ok
Bruce shaw
Bruce
32 REPLIES 32
Message 1 of 33
Message 2 of 33
Just checked I haven’t done the 18.2 iOS update yet still on 18.1
Bruce
Message 3 of 33
Hi @Bruceshaw
Ah ok, so none of your apple devices have updated recently to the latest IOS version.
Our engineers are aware that it's affecting all devices but just wanted to check about certain devices too.
Message 4 of 33
I’m on 18.1 iOS
But have tried only connecting one device at time
lg tv
xbox series x
iphone
Internet still goes off regardless
Bruce
Message 5 of 33
@Bruceshaw
I know this will be affecting different devices, we just need to check if you do use any apple devices too and if these apple devices have IOS version 18.2 IoS release?
Message 6 of 33
Hi @Bruceshaw
Yes I've cancelled the TalkTalk engineer visit for you now.
Question from our engineers - Can I just check specifically what devices are affected when this issue happens please? Is it related to Apple devices only?
Message 7 of 33
Would you be able to cancel the visit then
thanks
Bruce
Bruce
Message 8 of 33
Hi @Bruceshaw
If it's the same fault with connection dropping but the white light stays on the router then this will be linked to the wider issue and an engineer visit would not be required.
Our engineers are working on a fix for this issue.
Message 9 of 33
Do I still need my engineer appointment of it’s a wider issue than just mine?
Bruce
Message 10 of 33
I'm sorry to hear this. We have fed this back to our engineers and we're currently awaiting an update from them this morning. We'll post back here as soon as we know more.
Message 11 of 33
Tried the new router setting still no joy keeps cutting out every 40 mins have you found any working solutions yet? seen some people mention when they use none talktalk routers it works fine is this the only model you have?
Bruce
Message 12 of 33
Hi @Bruceshaw
Yes this is affecting some customers (but not all) This is why our engineers are trying to replicate this fault.
Message 13 of 33
How many people are experiencing the same issues is this a wider issue than just a couple of people?
Bruce
Bruce
Message 14 of 33
Hi @Bruceshaw
We have asked some other customers also to try this (with the settings) I will let you know as soon as I hear if this resolves this issue.
Message 15 of 33
I’m currently at work away from the property so will have to try tonight around 5pm
thanks
also did manage to speak to someone on the phone on Saturday a talktalk engineer is coming out Wednesday afternoon to investigate
Bruce
Message 16 of 33
Hi @Bruceshaw
Apologies for this.
Our engineers are investigating this issue and they have asked if you can try the below:
Change your router DNS settings to use Google DNS.
  • Open your web browser, type http://192.168.1.1 into the address bar and press Enter
  • Enter the username admin (in lowercase) and password (you'll find this on the removable settings card on the back of the Hub, and select OK
  • Select See internet settings
  • Select Manage advanced settings
  • Select TalkTalk WiFi Hub
  • Select DNS Tab
  • Make sure ON is enabled
  • Add Primary and Secondary DNS Servers ( Primary = 8.8.8.8  Secondary = 8.8.4.4 )
  • Select Apply
Please note ;  If you currently use any Homesafe services such as Homework Time etc.  This will not work whilst you have the DNS set to Google.
DrWig
Message 17 of 33
I've received my router (for the same issue) but I haven't had a chance to plug it in yet.  Since switching to my old/emergency router, my connection has been rock solid, so I'll report back once I have (I have a thread, but I'm happy to let you know, too, Bruce.  Us Bruce's need to stick together 🙂
Bruce
Message 18 of 33
Good morning,
Our Escalation Team are currently looking into the issue with no connection/white light on router and we're hoping to know more later on this morning.
Message 19 of 33
OK, thanks for trying and confirming that. Please wait for the support team to pick this up again when they are back online on Monday.
Message 20 of 33
wifi has dropped again using the test port and wouldn’t restore without power cycling the router
Was using all the new equipment that came with the new router
Bruce
