Router not working
Bruceshaw
Message 33 of 33
Hello
having issues with my WiFi router, keeps cutting out after every 30 minutes (no connection) power cycling the router restores connection but not for long
having to power cycle it at least 10 times a day.
seen other people post similar issues and a new router has sorted the problem
would a member of talktalk staff be able to send me a new router tried getting through on the online chat but don’t seem to get a response?
also router constantly shows a white light which indicates all should be ok even when the connection stops
nothing has changed in the household to make it stop working and tried line checks on website which state the line is all ok
Bruce shaw
Bruce
32 REPLIES 32
Message 21 of 33
Thanks,
just did that never realised that was there WiFi is on will have to see how it goes as normally is fine for 30-40 mins
Bruce
Message 22 of 33
OK, you can remove the faceplate on that by gently squeezing the clips on each side, you will find the test socket behind there. Try connecting to that using the new plugin microfilter and cable which accompanied the replacement router. Make sure you are using the new power supply also.
Message 23 of 33
Mines the one labelled nte 5c
has an adapter that comes out for the broadband connection and phone connection
don’t actually have a phone/handset though
Bruce
Message 24 of 33
Message 25 of 33
Master phone socket don’t have a test socket
Bruce
Message 26 of 33
Where is your router connected? The master phone socket, or an extension? If the former, have you tried connecting at the test socket?
Message 27 of 33
Hello new router has arrived however still same issue
WiFi will work for about 30-40 mins then cut off
light stays white on hub indicating it’s all ok but won’t work on any device
also logged into router via IP address and this shows it’s offline and not connected to internet
also tried further tests, noticed when it’s working fine if I pull the phone line out the back of the router light turns from white to red as it should, however when WiFi stops working and I pull the phone line out the router stays white when it should go red as no phone line connected? Seems to be indicating something wrong with the router? As line tests show all ok has been playing up since Tuesday now and is getting really frustrating is there something wrong with the firmware or some setting in the router?
I haven’t changed anything on the new or old one for it to start playing up
need this sorting asap
Bruce
Message 28 of 33
Hi @Bruceshaw
The line tests are clear so I've sent you a replacement router, please allow 24-48hrs for this to arrive.
DrWig
Message 29 of 33
Exactly what I'm doing..... 🤔. Thought he might like to know it might be a wider issue....
Message 30 of 33
@DrWig, please just follow up on your own thread.
Staff only respond to the original poster and will look at your own topic during the day.
@Bruceshaw, hasn't had a chance of a reply on here yet!
Message 31 of 33
@DrWig
I see you have started your own topic, wait for a response there and leave this one for the original poster's issue.
DrWig
Message 32 of 33
I've come on here as I'm getting exactly this issue starting today! Has a new firmware been pushed out?
Anonymous User
