Huawei Phone
Jimok
Message 6 of 6
Hi,  I've been checking the connections to my router and just looking for a bit of information, i see a connection named Huawei_Phone via ethernet and was wondering if it is just a daily connection to Huawei from the router, thanks in advance for any help received.
5 REPLIES 5
Message 1 of 6
Thank you so much for the support @Divsec
Hi there @Jimok Thank you for informing us, the issue is now resolved.
Have a lovely day and take care:)
Message 2 of 6
Thanks for letting us know, glad you are sorted!
Jimok
Message 3 of 6
Hi Guys, it turns out the Huawei_Phone was my TT Set-Top box, it shows up as Android on "My Devices", thanks for your help.
nomfezeko-TT
Message 4 of 6
Hi there, thank you @Divsec for the support. @Jimok, thank you for reaching out with your question! The connection named Huawei_Phone that you're seeing via Ethernet is likely associated with a device connected to your router, such as a Huawei phone or another Huawei device. This connection is not a daily connection to Huawei itself; rather, it indicates that a device is currently linked to your router.
Divsec
Message 5 of 6
Hi @Jimok it would make sense if you have WiFi signal boosters and a Huawei phone.
