on 26-04-2025 09:10 PM
The internet is constantly dropping.
Ive already been sent a new router.
They reset it all this afternoon and it was better for about an hour, now its dropping constantly again.
I can’t believe I can’t talk to anyone past 8pm! I’m supposed to wait until tomorrow morning with useless internet?!
on 24-06-2025 05:16 PM
It won’t let me send any more private messages. Yes everything is back how it was
on 24-06-2025 04:12 PM
It was a talk talk engineer. And no. It doesn’t fit.
on 24-06-2025 03:56 PM
What kind of "engineer" was this? Can you post a clear picture of the microfilter in question, showing all the connectors?
on 24-06-2025 03:38 PM
So what happens now?
No it won’t fit due to the shape. The engineer that visited, confirmed this
on 24-06-2025 03:33 PM
OK, can you not use that to connect at the test socket?
on 24-06-2025 03:27 PM
Please reattach your faceplate back onto the master socket and everything else as it was okay. Thanks
We can see the line test still indicating an internal wiring issue after your equipment was disconnected, so this will need further investigation. Thanks
on 24-06-2025 03:24 PM
That’s a micro filter, that doesn’t fit and is not connected in any way
on 24-06-2025 03:11 PM
Sorry to intervene, but @AmberParlsow what is that white item, partially visible towards the bottom of yourn picture? The cable appears to be going via that, rather than directly to the socket.
on 24-06-2025 03:10 PM
A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 5 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
on 24-06-2025 03:09 PM
I am about to run a test that will look at the condition of your line. This test will identify any faults in the cables and associated equipment, between your home and the exchange, that could effect your service.
The result will allow us to determine if an engineer is required, or whether additional checks need to be completed with you. Thanks
on 24-06-2025 03:04 PM
Yes
on 24-06-2025 02:33 PM
I take it you were able to remove the faceplate, correct? Thanks
on 24-06-2025 02:32 PM
I do not have the “spare adsl filter”
on 24-06-2025 01:30 PM
Oh yes, I understand. I don't know how we going to do it but I've provided a link with steps you'll follow okay. Thanks
Your guide to main phone sockets - TalkTalk Help & Support
You use the video and after following the steps please let me know how it goes. Thanks
on 24-06-2025 01:16 PM
Sure - or just tell me. I just can’t confirm anything to you.
on 24-06-2025 01:15 PM
Would it be possible if I were to do that? Thanks
on 24-06-2025 01:14 PM
on 24-06-2025 01:13 PM
I can send you a video which will show you how. Thanks
