Intermittent connection - support no real help
lancsgent
Message 16 of 16
I am having an issue with the internet connection where the connection is dropping several times a day sometimes several times an hour. Been on to the online chat a few times now - all they ever do is upgrade the firmware on the router and offer to send me a leaflet on how to configure the device that is having problems to the WiFi when the entire connection is going down and all devices including wired ones disconnect so it is not a device issue. Once the internet comes back the agent declares the problem fixed and the whole circus starts again, what do I need to do to get the fault investigated rather than be fobbed off? For the record the router has an orange light then orange and white then white again?
15 REPLIES 15
Message 1 of 16
Just checking back in to see how your connection has been?
Message 2 of 16
How has your connection been over the weekend?
Michelle 🙂
Message 3 of 16
That's great lancsgent, we'll check back in with you on Monday to make sure everything is still OK
lancsgent
Message 4 of 16
Thanks for your help with this! Today has been the first day in a while when the connection hasn't reset so fingers crossed!
Message 5 of 16
I've re-checked and we've received an update to advise that Openreach have located and repaired an external cabling fault. I'll check back in with you on Monday to see how the stability of the connection has been following this.
Message 6 of 16
Good afternoon,
Thanks for confirming. I've re-run the line test again now which is still detecting a potential faullt so I've passed this over to Openreach now for an external line investigation to be completed. I'll check again first thing in the morning for an update and will post back as soon as I know more.
lancsgent
Message 7 of 16
I thought I should add to that that the internet connection runs at full speed when it isn’t disconnecting which is probably what is making it so hard to diagnose!
lancsgent
Message 8 of 16
I seldom use the landline but haven’t noticed any issues.
Message 9 of 16
Thanks. I've run a line test now which has detected a potential fault. Can I just confirm, are you experiencing any issues with the voice service such as noise on the or no dial tone please?
lancsgent
Message 10 of 16
Community details now updated
Message 11 of 16
  • Name
  • Telephone number
  • Alternative contact number
Message 12 of 16
@lancsgent, your account number is personal information and must not be on public display. Go via your avatar/name; settings; from the drop down menu choose Personal Information.
Add your Talktalk landline number where asked, or your account number there or in Private Notes at the end of the section.
SAVE CHANGES.
lancsgent
Message 13 of 16
Account number is REMOVED FOR SECURITY REASONS - thanks
Chris-TalkTalk
Message 14 of 16
Hi lancsgent,
If you still need assistance can you please add your TalkTalk home telephone number or account number to your community profile and we'll be happy to help
Message 15 of 16
