Need a new router after 4-5 years...
TorqueTorqueBIS
Message 32 of 32
Good morning
Any chance to get a a new free router sent to us?
After 4-5 years and also being an old model, I guess it is time.
Better, if it had external antenna or antenna socket.
Please reply with what to do - I am never here and do not know how you work.
Email does not exist any more with larger Companies, therefore forum it is!
M
TorqueTorqueBIS
31 REPLIES 31
Message 21 of 32
Hi TorqueTorqueBIS
I can send you a replacement router and a returns bag for your current one. Would you like me to arrange this?
Message 22 of 32
You can use Live chat to contact TalkTalk if you wish:
Message 23 of 32
... another thing I was reminded just now!
Server throw me out - i.e. logged me off, after a certain time.
So I wasted time in writing a reply, forced to login again and lost all I have typed in!
I forgot about it or I would have copied it into notepad!
1. Model is not mentioned over the external box on any label
2. Model only found when I logged into it:
FAST5364 3.00
Firmware Version: SG4K100136
GUI Version 5.6.1
note: I though I did mention model when I was asked.
Must have forgotte, I am working at home at present.
3. Environment? Just Recycle.
That is simple, although No Government 'ever' impose a replace and return to Large Companies - obviously!
4. Antenna, was only 'mentioned' in case they had one 'eith them on' - that was all.
I just do not have the time and do not wish to give an excuse for 'tampering'.
I would have modified it with antenna socket (I am a technician) - as I used to work with radio/TV/telephone/communication devices at component level - a long time ago.
A 'real' technician 'does not tamper'.
5. time to go elsewhere - nothing to do with modem, but with service.
In the end there is BT everywhere now - it is a monopoly, including TalkTalk (EE, Plusnet, etc. ALL BT or subsidiries under different names).
Thanks for replies
M
PS I have just given up, I cannot spend ages on a forum because they force me to phone them when I have a hearing problem and 'always' connect with suppliers and retailers via email of even chat = fast and efficient and avoid misunderstanding.
TorqueTorqueBIS
Message 24 of 32
@TorqueTorqueBIS wrote:
Pff
Time to go elsewhere...
You mean you're considering switching to a different ISP unless TalkTalk supply you with a new router?
That's a rather strange attitude.
As others have said, they will generally only supply a replacement router if the one you have has developed an actual fault (or is incompatible with a new service you have upgraded to).
They supply a router to every new customer to allow you to access the internet service and we all pay for this as the cost will be built into the service charges. I don't imagine any ISP will supply a brand new router every couple of years. As well as the cost of all these routers (which would probably be covered by increased service cost to all customers), I'm sure that in this day and age they would face pretty stern criticism from environmental groups for the wasteful nature of that practice.
Having said that, staff may be kind to you and send you a new router if yours is a very old model. You haven't actually specified what model it is, but if it's only 4 to 5 years old it's probably one of the more recent ones
If you want/require a router with specific features (you mentioned external antenna) not present on the ISP supplied routers, you always have the option to purchase and use your own router, as many of us do.
Message 25 of 32
What's wrong with your service/performance at the moment?
TorqueTorqueBIS
Message 26 of 32
Pff
TorqueTorqueBIS
TorqueTorqueBIS
Message 27 of 32
Right!
TorqueTorqueBIS
Message 28 of 32
Sagem ceased to be around 15 years ago; you are probably thinking of Sagemcom. All their routers are made in China, in common with most tech companies these days. They remain the currently provided models and overall have a good record of reliability and performance. TalkTalk will explore a swap out for you if you can point to any specific issues you may be having other than that it is "quite old."
TorqueTorqueBIS
Message 29 of 32
Ideally, one should replace them once every 1-2 years really!
TorqueTorqueBIS
TorqueTorqueBIS
Message 30 of 32
C2A239
Reason I asked is simply they get 'quickly' old - the transmitter components - as they are not very well ventilated and 90% of those given by Internet suppliers are low quality Sagem from France.
Nothing against French - it is just the VERY low quality of their routers, which also is the reason they are mostly free.
I used to deal with Sagem many years ago - Freeview Receivers at the time.
PS I am a Technician... and I used to work with Radio Transmission and repairing them in Airports.
TorqueTorqueBIS
Divsec
Message 31 of 32
Hi @TorqueTorqueBIS you don't mention which router you have? Rule of thumb is if it ain't broken don't fix it. None of the TT routers I've seen have external antenna.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
