Network switch causing issues with eero 6
Paulyoung987
Message 9 of 9
If I plug my netgear  smart switch into the 2nd port of my eero  6 withon 5 minutes it crashes the Eero 6 has anyone else had this or have a solution for this issue ?
8 REPLIES 8
Message 1 of 9
Hi Paul,
How are you getting on?
Message 2 of 9
Thanks again keith I will need to check the settings but don’t think so I’ll take another look tomorrow and come back
Message 3 of 9
Just a thought, you haven't configured a static IP address on the SFP port that is within the DHCP server's IP address range? This would be risking a duplicate IP address which might take the switch port down.
Message 4 of 9
Is the SFP port set to auto-negotiate speed & duplex? If it is, try locking it to 1000M full duplex, I have seen similar issues with switch ports in the past.
Message 5 of 9
Yes tried a factory reset and tested the cable between the two all looks to be fine but still falls over after 5 minutes or so ! Very annoying
Message 6 of 9
Have you tried another Ethernet cable? It looks to me that the SFP ports are the trunk or upload ports, I assume that one of these is connected to the Eero? I don't know how configurable this switch is, have you tried a factory default of it?
Message 7 of 9
Thanks for the reply keith it’s a Netgear GS716T
all and as working perfectly and has done for some years until I upgraded to the Eero6 faster broadband now 5 minutes after plugging in the switch to the 2nd port the Eero falls over and red light comes on
Message 8 of 9
Which model switch is this?
