Mobile support
For any questions about your TalkTalk mobile service.
Wifi Calling Not Working
Hedge23
Message 3 of 3
I'm trying to set up Wifi Calling on a Xiaomi phone. I appear to have it sorted, on the phone itself (set as on, in the phone app, carrier check disabled etc). But when I try a test (airplane mode but with wifi back on) I get "Mobile network isn't available. Connect to a wireless network to make a call."
But I'm connected to the network so something else is wrong.
Any ideas? I read about router firmware issues somewhere else on the forum. Could that be it?
Message 1 of 3
Thanks, fr8ys.
No, I haven't tried another network.
I'm with Talktalkmobile. (If you meant Xiaomi, the manufacturer, then it's quite an old phone but, yes, there are a few comments, from some years ago. But they seemed to be solved, for the posters, via the "disable carrier check" stuff.)
You said you were missing a stage...wonder if I've missed something, too. Was it something straightforward? (I've rebooted, of course. No joy.)
Message 2 of 3
WiFi calling should work whenever you are connected to a WiFi network, not just your home one.
Have you tried on another network to see if you can connect there?
I had issues myself with Lebara and finally found the solution on Google and found I was missings a stage. I also had to reboot my phone to get it to work.
Have you checked your mobile providers site or forum to see if others have had similar issues?
