No broadband, No update with fault for 36 hours
Victoriastu
Message 8 of 8
How do I get an update on the fault I logged at 9:51pm on Saturday evening? It's now Monday morning and it is STILL saying I will have an update in 5mins. I need to work from home in 1 hours time... HELP
I can't find live chat and it won't let me raise a new fault.
I need to know whether I'm in the queue for being sorted or if my fault has got stuck? It's been saying I'll find out in 5 mins for so long!
Victoria Moore
7 REPLIES 7
Message 1 of 8
Hi Victoriastu
I've ordered a router, it should be with you within a couple of working days
Message 2 of 8
Hi Michelle,
Can you give me an update please?
How quickly can you get a replacement router to me please?
Victoria
Victoria Moore
Victoriastu
Message 3 of 8
Yes, there is a dial tone. Please do order a replacement router for me as a priority and i did log this issue on Saturdayeve and had no update for all of yesterday. This is having a massive impact on me for work.
Victoria Moore
Victoriastu
Message 4 of 8
Victoria Moore
Message 5 of 8
Hi Victoria,
Thank you. I've run a few different line tests now which are all clear, however I can see that the router is not currently in sync and connected. Is your voice service ok and do you have a dial tone? Does your main socket have a test socket? Do you also have an alternative router that you can test with please? If not then we can send a replacement router for testing purposes to rule this out.
Victoriastu
Message 6 of 8
Hello Michelle,
Thanks for your message, I have updated my community profile with the info you requested.
Victoria
Victoria Moore
Message 7 of 8
Good morning,
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
