on 01-04-2023 11:21 PM
Been with TT since Sept23, was getting connection in excess of 45/50Mbps, with a guaranteed minimum of 47.
Since mid feb, not been getting anything over 35. Nothing has changed in the property. TT sent out an engineer who confirmed that there is no issue with the wiring at the property. That was 10 days ago, i've heard nothing since.
I want my minimum speed. I dont see why i should be paying 100% of my bill to only recieve 75% of my services
on 03-04-2023 11:19 AM
Hi Varil,
I've sent you a PM requesting a little more information
on 03-04-2023 11:04 AM
I accept
on 03-04-2023 10:56 AM
OK thanks, if you'd like us to arrange the engineer visit can you confirm:
on 03-04-2023 10:54 AM
Wednesday after Easter, all day I'm free.
Saturday this week before midday is good too
on 03-04-2023 10:53 AM
OK thanks, would you like us to arrange an Openreach engineer visit?
on 03-04-2023 10:52 AM
Just checked my records and engineer came on March 22nd.
They checked line etc in property and told me it would be escalated to Open Reach as the issue was on the network. I've heard nothing back.
on 03-04-2023 10:51 AM
The engineer will be an BT Openreach engineer, they'll be able to check the line
on 03-04-2023 10:44 AM
I had an engineer visit 2 weeks ago, they found no issues in the property. They said the issue was on the network
on 03-04-2023 10:43 AM
OK thanks. We can arrange an engineer visit to investigate, if you'd like us to do this please let us know and we'll confirm some details with you
on 03-04-2023 10:41 AM
Don't have a handset attached to check. Never used the line for calls
on 03-04-2023 10:26 AM
OK thanks. Are you experiencing any problems with your telephone service, any noise on the line?
on 03-04-2023 10:20 AM
It is yes
on 03-04-2023 07:57 AM
Hi Varil,
Line test is passing but your sync speed is low and there have been some disconnections over the last few days. Is your router currently connected to your test socket - Your guide to main phone sockets - TalkTalk Help & Support
on 02-04-2023 01:37 PM
Package is Fibre65, danced through all those hoops with webchat multiple times to no avail
Technician came out and looked at the set up, no issues, said they'd get some one to look at the network outside the property but I've heard nothing since
on 02-04-2023 12:07 PM
Hi just curious. What package have you., and have you tried switching off router for 30 mins then powering back on to see if it connects at higher network speed. Does work most of the time.
Otherwise an OCE will be available on Monday office working hours
