Poor Speeds Today
JaceyBoy
Whizz Kid
Message 32 of 32
Hi, can someone do a check for me, im getting 21.6 down and 20 up, normally get around 55 down and 20 up....
Jason
31 REPLIES 31
Message 1 of 32
Hi JaceyBoy
How's the connection been since your last post?
Message 2 of 32
Hi Michelle, its set to auto right now and I set the Bandwith to 40mhz for 2.4ghz and 40mhz for 5ghz and it seems to be working okay so far...
Jason
Message 3 of 32
Can I just confirm, have you tried a few different wireless channels since your last post?
Message 4 of 32
Weird now my gates are offline also, what is going on?
Jason
Message 5 of 32
Wifi optimisation usually works fine but it's possible that it's automatically changing your wifi channel to one that doesn't work particularly well. You can now change the wifi channel manually without wifi optimisation interfering
Message 6 of 32
Why does it interfere so much? hopefully this might sort the issue
Jason
Message 7 of 32
OK thanks. It was switched back on so I've disabled it again
Message 8 of 32
2710
Jason
Message 9 of 32
Could you give me the last four digits of the router serial number so that I can confirm that I have the correct one
Message 10 of 32
I'll just check if it's off
Message 11 of 32
Yes thats it can you turn it off?
Jason
Message 12 of 32
We can't turn DLM off, do you mean wifi optimisation?
Message 13 of 32
This needs to be turned off as there was connection issues before?
Jason
Message 14 of 32
Do you mean DLM (dynamic line management)? Yes that is still active
Message 15 of 32
Is the SNR active? because when I was having connection issues last year we turned it off and that seemed to sort the problem with a new router?
Jason
Message 16 of 32
My son happens to be in the lounge, but his phone dropped out and also having problems reconnecting my Ring Doorbell since resetting the router to factory settings
Jason
Message 17 of 32
Hi Jacey,
Does Netflix freeze on more than one device?
Message 18 of 32
Chris, still getting connection problems, also Netflix etc is freezing, showing me 51 down but dont think I am getting that, also my Ring Camera is not able to connect which is new?
Jason
Message 19 of 32
Message 20 of 32
Sure it maybe just a hickup, we do have a fair few devices connected
Jason
