on 09-03-2023 12:14 PM
Hi, can someone do a check for me, im getting 21.6 down and 20 up, normally get around 55 down and 20 up....
on 09-03-2023 02:15 PM
OK thanks. Could you see how it goes the rest of today and bump the thread tomorrow, we can then check the line history for disconnections and errors
on 09-03-2023 01:57 PM
Only one
on 09-03-2023 01:56 PM
Thanks. How many telephone sockets do you have in your home?
on 09-03-2023 01:51 PM
No, just had a phone call and all clear
on 09-03-2023 01:50 PM
OK thanks, are you experiencing any problems with your telephone service, any noise on the line?
on 09-03-2023 01:39 PM
Hi Chris, nothing has changed, but yes its connected to the master socket
on 09-03-2023 01:24 PM
It could be the SNR fluctuating. Is the router currently connected to your test socket?
on 09-03-2023 01:02 PM
Hi Chris, back up to 52 down but the router is struggling with connections, I wonder if its on the way out, it was only replaced around three months ago?
on 09-03-2023 12:28 PM
OK thanks 🙂
on 09-03-2023 12:25 PM
Hi Chris, will do, I did a reboot through firmware but will do a full recycle
on 09-03-2023 12:22 PM
Hi JaceyBoy,
Line test is passing but sync speed has dropped. The speed drop isn't due to a profile change so could you switch your router off and leave it off for at least 30 minutes then switch back on and retest - please let us know how you get on
