on 05-02-2025 08:02 PM
Every couple of days when I turn the TV on I have to reconnect to my wifi.
I spoke with someone via chat and they initiated a firmware update for the Eero which they thought would solve the issue, however today I had to reconnect to the wifi again.
I am not actually sure if the problem is with the Eero. Is it possible that the issue is with the TV box?
Everything else works fine! I am getting great speeds and the internet appears fine, which is why I am wondering if the TV box is actually the problem.
Many thanks Dave.
on 21-02-2025 09:00 AM
You're Welcome 🙂
on 21-02-2025 08:53 AM
Hi Karl
Thank you very much.
on 20-02-2025 06:13 AM
A replacement is on the way.
on 19-02-2025 03:03 PM
Hi Karl
That would appear to be the only option doesn't it?🙁
Thank you for your help!
Best wishes Dave.
on 17-02-2025 08:04 AM
Would you like to swap out the TV Box?
on 13-02-2025 04:29 PM
Hi Karl
Ironically having sent the update yesterday today the box dropped the WiFi again today and I had to reconnect. Is there anything else I can try? I was hopeful that the factory reset had done the trick! 🙄
Best wishes Dave.
on 12-02-2025 08:04 AM
No Problem 🙂
on 11-02-2025 05:47 PM
Hi Karl
Just to give you an update.
I have done a full factory reset and so far so good!
👍😊 Best wishes Dave.
on 07-02-2025 07:41 AM
No Problem 🙂
on 06-02-2025 07:12 PM
Hi Karl
Okay I will give that a go and let you know what happens!
Best wishes Dave.
on 06-02-2025 07:41 AM
Try a full reset of the TV box to see if it keeps dropping the Wi-Fi
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
