Poor speed to devices
on 19-11-2024 02:34 PM
Message 11 of 11
I am having trouble with low speed to my Apple devices. I have run a Talktalk speed test, which shows good speed to the router, but poor speed to both my iMac (52Mbps) and my iPhone 13 (9Mbps). I am on Fibre 65. The router is Sagemcon TalkTalk Wi-Fi Hub FAST 5364.
The problem is particularly noticeable with my iPhone 13 (my old iPhone 8 has no connection issues or dropouts), which shows it's connected to WIFI, but there is no internet connection once the phone is woken from sleep. I have to toggle airplane mode on and off to get it to come on again.
Also, the last couple of days the phone reception has been really poor when connected to WIFI, not sure if that's related.
Any help would be most welcome. I have seen similar issues mentioned on this forum, @KeithFrench
Labels:
- Labels:
Connection
Stability
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
10 REPLIES 10
on 29-11-2024 07:44 AM
Message 1 of 11
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-11-2024 09:27 AM
Message 2 of 11
Thanks for your help @KeithFrench
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-11-2024 01:21 PM
Message 3 of 11
A summary so far of what I have found:-
Apart from the different names currently, your network looks fine. I would suggest that you rename one or both WiFi bands to whatever you want.
Saying that your network is fine though is only true for the current location of your Mac, where your phones drop out, it might be a different story. If the Mac is a laptop, please could you move it to bad reception areas & get me another set of screenshots?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-11-2024 08:20 AM
Message 4 of 11
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-11-2024 02:51 PM
Message 5 of 11
Hi @Freund
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-11-2024 02:48 PM
Message 6 of 11
Yes, please, any guidance on optimising my settings would be very much appreciated.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-11-2024 02:43 PM
Message 7 of 11
Hi @Freund
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-11-2024 02:42 PM
Message 8 of 11
Hi @Freund
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-11-2024 02:41 PM
Message 9 of 11
Yes, I turned off the router over night, but the issue is still there.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-11-2024 02:40 PM
Message 10 of 11
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
