Port Forward Settings for Synology NAS
AlanDeeeeee
Message 6 of 6
I'm trying to set up port forwardin settings for Synology NAS.
I know the external port but not the rest (se below) can anyone help?
5 REPLIES 5
Message 1 of 6
Thanks for your help @KeithFrench 🙂
AlanDeeeeee
Message 2 of 6
Perfect - thank you.
Message 3 of 6
This works (assuming it is TCP), I have just tested it.
Forward TCP port 5001Forward TCP port 5001
AlanDeeeeee
Message 4 of 6
Thanks Keith: 5001
Message 5 of 6
What TCP or UDP ports do you need to forward to access your NAS?
