Powering down the router for 30 minutes
Billx
Message 3 of 3
Hi, @Debbie-TalkTalk
I butted in someone else's topic just a while ago.
And I was informed that it would best to put the issue that arose there in a new topic.
So, I will repeat:
"I'd like to ask a question.
I was under the impression that if the broadband connection is full fibre, then it is the ONT that needs to be powered down for 30 minutes, rather than the router.
Am I misguided?"
Bill
Billx
Message 1 of 3
Hi, @KeithFrench
Thanks very much for your answer, really appreciate it.
(So I won't wait for Debbie)
Bill
Message 2 of 3
No, @Billx, I agree with you. It is the ONT that needs the 30-minute power down, as that termiates the full fibre line.
