ROUTER
denispannett
Message 2 of 2
I need to know my router user name and password which are not on the router it's self
1 REPLY 1
Gondola
Message 1 of 2
Look on the router label and tell me the router model number.  Whilst you're there look for the router login to 192.168.1.1 and username - it may be 'admin'.
The router username and password are on the sticker underneath the removable settings card on back of your Wi-Fi Hub. If your router doesn't have a sticker, your default username and password will be set to 'admin'.
