Replace Talk Talk router
Billybob6
Message 3 of 3
Hi I have fibre 150 via a BT modem to the standard TT router, I have purchased a TP Link AC2100 router to replace it.
I am have great difficulty getting it set up, I can access the new TP router and use the "easy start setup" but it fails every time, all cables are correct but im not sure of the manual settings if I go that route,
Anybody have any suggestions
Message 1 of 3
Hi @Billybob6
I can see that our Community Star @ferguson has linked to our help page for setting up a non TalkTalk router.
Message 2 of 3
No more than is available here:
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
Otherwise, I suggest you reach out to TP-Link directly.
